Old 05-07-2020, 11:49 PM   #192 (permalink)
Xist
Arizona here, is that the "Green" that is all the rage in other states?
Can someone tell me what Monopoly would be like if each time that you passed Go you received more and more money?
I stopped by the house after my one Thursday client. The paint is flaking off. A pressure washer would make short work of that, right?
It looks like there is dry rot. Good thing that is cheap and easy to fix!
There are chain-link fences on the right and back, but not on the left. The next house is surprisingly close. I guess that the only way to put in a fence on that side is to put the gate straight back from the house, which is all kinds of weird.
This is across the back fence. Does it look abandoned to you? If I were to look for distressed houses off of the market I would start right here.
The television antenna can come down, right?
It looks like every window and door frame has cracks above and below the corner. It looks like someone replaced pieces of drywall in the kitchen with OSB. One door is missing a frame and it looks like they ripped out a window [or at least the inside trim], it ripped off the paint, and the new trim is smaller than the old stuff, so all of that needs to be patched. The baseboard in that room is missing and the blinds are broken. The floor is missing at least one linoleum tile, but I expected the entire floor to need to be replaced anyway. The shower enclosure does not look right to me. Clearly it needs to be re-grouted, but it looks like it came in pieces that fit together poorly. Also, it appears someone removed the window trim. That looks like Great Stuff with paint over it.
What I can see of the floor is okay, but the sink is mounted to the wall?
Somehow I do not expect that to hold up. Also, apparently all of the storage is the wire racks next to the toilet.
Another room is missing the frame and it does not look like it ever had baseboards.
That makes it easier to replace the flooring.
If the dry rot and paint aren't too bad, honestly, it should not take too much work to fix up, but every project has hidden expenses.
Do you guys see anything that I missed? https://www.zillow.com/homedetails/1.../8410334_zpid/
People are insulting and cursing me for various comments that I have left where I intentionally and maliciously used math and reason.
I usually read the first couple of words and move on.
Name:	1221 Hunning 13.png
