I've been doing some printing!
This is the top plate. Its printed fairly dense, and it is thicker than the other panels because it will have the handle attached to it. This meant it took 16 hours to print.
Next up we have the plug panel. This will be screwed into the end panel that has yet to be printed. Next to that is the switch mounting plate that I talked about a few posts ago.
And here we see how the switch mounts up to the top plate with the switch mount.
Next up are two little button extensions. Since the buttons on the low voltage cutoff are so low, I needed to print extensions so they would stick up and out of the top plate.
Now I can mount the low voltage cutoff circuit board up to the top plate.
And a view from the top. I'm very happy with how this is turning out.
