05-08-2020, 07:51 PM
#210 (permalink)
How is this a benefit? Hmmm...
More people will learn about code review. And GitHub.
https://lockdownsceptics.org/code-re...rgusons-model/
This is MacOS Summarize Text set to about 10% Sentences:
In issue 116 a UK “red team” at Edinburgh University reports that they tried to use a mode that stores data tables in a more efficient format for faster loading, and discovered – to their surprise – that the resulting predictions varied by around 80,000 deaths after 80 days:
...The explanation given is “It looks like historically the second pair of seeds had been used at this point, to make the runs identical regardless of how the network was made, but that this had been changed when seed-resetting was implemented”.
...Reports of random results are dismissed with responses like “that’s not a problem, just run it a lot of times and take the average”, but at the same time, they’re fixing such bugs when they find them. They know their code can’t withstand scrutiny, so they hid it until professionals had a chance to fix it, but the damage from over a decade of amateur hobby programming is so extensive that even Microsoft were unable to make it run right.
...Beyond the apparently unsalvageable nature of this specific codebase, testing model predictions faces a fundamental problem, in that the authors don’t know what the “correct” answer is until long after the fact, and by then the code has changed again anyway, thus changing the set of bugs in it.
...and set to parapagraphs*:
But Edinburgh came back and reported that – even in single-threaded mode – they still see the problem. So Imperial’s understanding of the issue is wrong. Finally, Imperial admit there’s a bug by referencing a code change they’ve made that fixes it. The explanation given is “It looks like historically the second pair of seeds had been used at this point, to make the runs identical regardless of how the network was made, but that this had been changed when seed-resetting was implemented”. In other words, in the process of changing the model they made it non-replicable and never noticed.
The Imperial code doesn’t seem to have working regression tests. They tried, but the extent of the random behaviour in their code left them defeated. On 4th April they said: “However, we haven’t had the time to work out a scalable and maintainable way of running the regression test in a way that allows a small amount of variation, but doesn’t let the figures drift over time.”
This bit of code highlights an issue Caswell Bligh has discussed in your site’s comments: R0 isn’t a real characteristic of the virus. R0 is both an input to and an output of these models, and is routinely adjusted for different environments and situations. Models that consume their own outputs as inputs is problem well known to the private sector – it can lead to rapid divergence and incorrect prediction. There’s a discussion of this problem in section 2.2 of the Google paper, “Machine learning: the high interest credit card of technical debt“.
Continuing development. Despite being aware of the severe problems in their code that they “haven’t had time” to fix, the Imperial team continue to add new features; for instance, the model attempts to simulate the impact of digital contact tracing apps.
My identity. Sue Denim isn’t a real person (read it out). I’ve chosen to remain anonymous partly because of the intense fighting that surrounds lockdown, but there’s also a deeper reason. This situation has come about due to rampant credentialism and I’m tired of it. As the widespread dismay by programmers demonstrates, if anyone in SAGE or the Government had shown the code to a working software engineer they happened to know, alarm bells would have been rung immediately. Instead, the Government is dominated by academics who apparently felt unable to question anything done by a fellow professor. Meanwhile, average citizens like myself are told we should never question “expertise”. Although I’ve proven my Google employment to Toby, this mentality is damaging and needs to end: please, evaluate the claims I’ve made for yourself, or ask a programmer you know and trust to evaluate them for you
*This is a typo, but I willingly and knowingly made it worse.
