Thread: Prius 75-91mpg
Old 05-08-2020, 08:26 PM   #146 (permalink)
cr45
Originally Posted by Nathan jones View Post
Ok guys bear with me, so theres a few changes I've had in mind, the rear bumper, Ive been thinking of butchering it for some time, this picture helps with the idea, the wheel covers, I may keep mine they are more aerodynamic and for the front bumper I may make the angle where the air is deflected upwards lower and increase the sharpness of the curve looking from above the car and fill the whole upper air dam area and smooth. Its hard to explain, also make new rear door sections but will use thin plywood to make proper molds. They wont be the same shape as the old doors but just like 3 door car shape. Hard to explain but that and some underneath work, maybe aluminium will be done. Hope to take 10 weeks off work and will take pictures...I only think maybe 104-106 but will be hell of a lot neater and white/black
...like I said I've reviewed weights and Cd's of many new and old cars (volvo c30 was a contender over the cr-z) including the newer c class mercedes (.22) and no matter what I could do would'nt match the prius for weight (the insight being too small). Even finding a bodykit like the one pictured which is now not around it will cost a fraction of the cost to take the time myself and buy in cf or vs buying a new car. May price up cf driveshafts too..
Have you considered the Mitsubishi Mirage - 2013 onwards.
845kg and 0.27 CD.
I suspect you could go sub 800 kg in a weekend.
They are the most efficient non-hybrid 5 person car on the market.
Even on short trips I am presently returning 75 - 78 mpg imp with just a grill block.
The Following User Says Thank You to cr45 For This Useful Post:
Nathan jones (05-09-2020)
