Thread: Prius 75-91mpg
Old 05-08-2020, 10:21 PM   #148 (permalink)
cr45
A member of Insight Central currently has his Insight down to 650kg with a roll cage and larger/heavier tires, and they're good for 120mpg imperial in stock form.
In the post I was replying to the OP said that he was ruling out the insight as it was too small for his requirements. My best so far in the Mirage is 92 mpg imp so I suspect the OP could break 100 mpg imp with only a fraction of the mods that he did to his Prius.
The Following User Says Thank You to cr45 For This Useful Post:
Ecky (05-08-2020)
