Old 05-11-2020, 09:56 AM   #3 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.42 mpg (US)
Originally Posted by California98Civic View Post
I imagine taking readings of two specific points on the dash every 3 or 5 minutes to see how temperature changes over time. I wonder about heat being transmitted across the dashboard however, so that my readings are confounded. Probably that would happen slowly though, with minimal effect. Thoughts?
Scanners are overkill. Search infrared thermometer. I have one that I bought years ago and it has worked, and still works, very well. The absolute accuracy is not all that great, but it's usually within 2 or 3 degrees F. The relative accuracy, where you want to know if one place is warmer than another, is better. I see that Home Depot has them for as little as $30.00: https://www.homedepot.com/p/Klein-To...-IR1/313516785.
Dashboards are plastic, which is a poor conductor of heat, so heat conduction from the hot side will be slow.
The Following User Says Thank You to JRMichler For This Useful Post:
California98Civic (05-12-2020)
