Old 05-11-2020, 07:04 PM   #9 (permalink)
cRiPpLe_rOoStEr
Originally Posted by iveco View Post
I will be not using the heated water directly it will be heating a 100-200 litre hot water tank on an independent loop, so I'm unsure how to stop adding heat to the water with out it running away.
A thermostatically-controlled bypass valve to regulate the water flow is the way to go.
