Old 05-11-2020, 06:09 PM   #49 (permalink)
2016 Versa
Little Blue Fuel Sipper - '16 Nissan Versa SV Sedan
90 day: 45.75 mpg (US)
Originally Posted by EcoCivic View Post
If you want it to last as long as possible I'd change the fluid at least every 30K miles.
My plans were already to change the fluid/filter approximately every 30K miles. I just bought fluid on eBay about a month ago in preparation for the first change. I still need to order a new filter and will probably get a new o-ring gasket for the filter housing in case I need it. I'm also planning to remove the pan so I can see how much metal shavings are on the magnets in the pan and clean them off to prevent any of them from breaking loose and circulating deeper into the system.
The Following User Says Thank You to 2016 Versa For This Useful Post:
EcoCivic (05-11-2020)
