Originally Posted by California98Civic
What is the overall weight of the wider tire versus the thinner tire? Because if a heavier tire out further toward the outer diameter of the overall wheel, it has a higher rotating mass effect. Lots to think about.
It's a pity that the weight of a tire is never mentioned as a specification.
The almost worn out tires that the car is now driving on, has already lost a lot of thread and therefore weight. Also tires have the least rolling resistance at the end of their life (but also less grip which I sometimes notice).
Anyway, the new tires must have a bigger diameter to change the gearing a bit. That's another aspect of tires.
Current 195/55 let the car go 62 (real) mph at 2000 rpm.
Taller 175/70 for example, would increase it with 5% (~65 mph) at same engine speed.
So yes, a lot to think about!
