I bought a megasquirt so I could try to tune lean burn in, but thats not the exciting revelation. I bought an extra computer so I could de-solder the plug off to make an adapter. This way I could plug the megasquirt in and not have to worry about driving the car while I try to get a good tune on it. I found a computer for a 94 escort automatic for $10 on ebay. After it sat on my desk for a few days I remembered the Lean on Cruise (LoC) that escorts supposedly had. So I decided to just swap computers and go for a drive. At first I didn't notice anything and the wideband didn't show any lean cruising. Eventually though the gauge stayed at ~18.x:1 for a little bit. I think I figured it out. I just go faster than I want to go (I was only able to get it to work above 53 mph) then dfco'd and gave it a little bit of gas. I was able to maintain the ~18.5:1 for about 6 miles before I had to turn. I was getting roughly the same mpg per the instant reading at 60 mph as I was getting at 40-45 mph on the original computer.
There are several things I need to check though. Does the MPGuino need to be recalibrated now that I have a different computer? My AFR gauge was cutting in and out for most of the run, it worked for the whole 6 mile section mentioned though. It was also the warmest it's been since winter so that is also influencing the results.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
