Old 05-17-2020, 05:01 PM   #12 (permalink)
oil pan 4
Doesn't the cat have overtemp isses when too much air is introduced?
The only time I have ever seen a confirmed melted catalytic converter was on an extended dyno run on a car that was definitely not running lean.
The fix for the melted cat was "run a bigger cat", as apparently this is a fairly common problem.
California98Civic (05-17-2020)
