Old 05-17-2020, 06:20 PM   #10 (permalink)
j-c-c
Originally Posted by guyd View Post
most 'standard' trucks in the UK (lorries..) have 'wind delflectors' mounted on the front vertical edge of the cab.
if you look to the left of the cab, you can see the effectivly sheet plastic 1/4 circle vertical deflector.
this is almost always described as a device to reduce dirt on side windows.
surely it helps with getting the air round the side? any ideas?
With experience driving a Semi, etc trucks, I think rain water is more the issue rather then dirt.
