Old 05-18-2020, 01:32 AM   #89 (permalink)
JulianEdgar
Originally Posted by aardvarcus View Post
I don't actually think the throttle position sensors are varying their output, rather the ecu/ computer is reinterpriting what that output means. Some of the newer chevy sensors have multiple potentiometers built in for redundancy, so the ecu is comparing those results and "deciding" the result.
Thus you would want to monitor the ecu output if possible. Not exactly sure on 95, my experience is with TBI (approx 94 back) and gmt800 (approx 99+).
At this stage, this technique is not endorsed for those cars with electronic throttle control or CVTs. So I am referring to mechanical throttle cars, where I found using a throttle stop, and then monitoring throttle blade position, best for consistency.
