I cleaned the wideband sensor and tryed again. Gauge stopped acting up and I got some useful data.
Originally Posted by Xist
I noticed a slight loss of power when I entered lean burn; I needed to accelerate slightly more even though I was on level ground
This is exactly what was happening as lean burn was activated. I took the hand brake lever from the metro and hooked it up as a throttle. I set it to ~65 mph and once lean burn engaged I would start loosing speed so I had to pull the lever another click or two to maintain 65. I was getting about 40-42 mpg (~17.5 k/L) at 65 mph (~105 kph). I also tested fastest and slowest I could go in lean burn. Fastest was 85 mph. The slow side of lean burn wasn't a hard cut off. From ~65 mph and up I was at 18.5 or leaner. As I slowed down however the richer it was. Once I got to about 50 I was back to 14.7:1.
At 45 mph I was getting 50 mpg at stoich. I've got 223 miles and at half a tank so far. Mpguino indicating 37 mpg on the tank. I'll have to finish making the mount for the hand throttle and do some testing (front wheel skirts & front airdam hopefully) to finish off this tank.
What is the slowest lean burn honda's can maintain lean burn?
Also a note to any escort/tracer owners looking into lean burn; I am running Potenza re92's which are 165/65 r14. Stock size is bigger (175/65 r14) so mph readings I've posted are accurate with the smaller tires.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
