I'm thinking that regardless of throttle type, there should be some measurable difference with a large enough change. The only likely variable is noise in the data. I don't know of any car that is setup to hold a set speed at a set throttle position, so with that consistent, load should translate to speed change.
2023 Kia EV6 GT
