Old 05-21-2020, 01:23 AM   #81 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
Aerohead, thanks for all your feedback. I spent a bit of time crawling over the vehicle today with a tape measure. There is a bit more room than I had remembered at the start of the cargo area prior to the window to patch in some compound curve. Looks like at least 6 inches growing to 9. The cargo area is already tapered in with a minor amount of compound curve (.45 to .90 to 1.18 degrees) as you go back. I am contemplaing the angle to set the sides. Doing some overlays, i am considering aiming for 6 degrees right after the 6-9 inch transition. That results in the vechicle sloping from 76 inches down to approximately 60 inches over a lenght of 69 inches, pulled in 6.5 more inches per side from stock. This seems to reasonably align with a 4:1 streamline from a top view.
There really isnt a constraint on the angle i set provided it stays between 4.2 and 7.3 degrees, with rear widths between 64 and 57 inches for that range. Obviously this is a big project so I would like to squeeze out as much as possible.
The Following User Says Thank You to aardvarcus For This Useful Post:
aerohead (05-22-2020)
