Old 05-21-2020, 06:42 PM   #25 (permalink)
roosterk0031
I'll take 4wd, and suspension articulation over .3" of ground clearance at the lowest point anyday.
I bet the "off road" Prius gets stuck on wet grass with a slight slope even with the best tires.
Is there wet grass down under? Saying the guy that got his Impala stuck in the drive way a few weeks ago and had to use a Rogue to pull it out.
