Old 05-23-2020, 10:17 PM   #513 (permalink)
freebeard
There ought to be a way to smooth jagged edges, no?
The edge doesn't have to be jagged, for instance if it is sheared. But it is three layers. The aluminum skins are finished, but the center is black plastic. A cap strip is all that's needed.
Are you suggesting it would not lay flat on the decklid?
Observe the [saddle] curvature of the front edge of the decklid. A flat sheet would have a slight crown for most of it's width with a roll triangulated off the front corners to the curved rear corners.
California98Civic (05-24-2020)
