Old 05-25-2020, 01:07 PM   #46 (permalink)
GreenTDI
GreenTDI's Avatar
GreenTDI - '11 Skoda Fabia Estate R3 1.2 CRTDI
Diesel
90 day: 65.02 mpg (US)
The solution is to take it out on the highway for a high speed periodic full throttle "tune up" of about 100 km.
Regeneration happened today, noticeable by the higher idle speed and a burning smell. So he definitely needed it.
Full throttle is not recquired for starting this cycle because it wil only happen in 4th and 5th gear between 1800 and 2500 rpm, as stated in the manual.
Originally Posted by ptitviet View Post
Regarding your problem : did you get an EML light? Best thing would be to look then to the fault codes. Otherwise, maybe you turbo is a bit dirty and variable geometry was getting a bit stuck?
I had no lights or anything. It just drove like there was no turbo for a while. It will have a service in two weeks, then we'll see if there are some error codes.
But I put the TDI on work today, revved it up to 4000 rpm a couple of times. In July I will let the engine stretch his legs on the Autobahn It helps for a better MPG afterwards.
See my thread: https://ecomodder.com/forum/showthre...mpg-38318.html
