Old 05-26-2020, 10:20 AM   #7 (permalink)
Piotrsko
The spin it question was more of a final fail point. If they bearings are sintered bronze AND the motor is easy to remove then I would lube them and see how far I could get. If the bearings are ball bearings, that is fatal. Should be able to determine which is installed from the fan side of the shaft.
California98Civic (05-27-2020)
