Old 05-26-2020, 04:57 PM   #261 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
(But I am still struggling to understand how that helps on engine modifications, as you suggested.)
An engine that is more effectively extracting energy from the fuel being inserted will go faster by translating more power off the same fuel at the same throttle setting. EG :this would allow modifications targeting a specific throttle% setting.
If all the parasitic losses are isolated meaning not changed,then a positive or negative result in speed is to the engine modification.
especially if it is repeatable with Aba.
In my opinion motor modification testing in this manner would have to occur with absolutely no crosswind. Julian has kindly demonstrated and charted how much of a skew this is had on the Windows Up Down Baseline test
Julian may I suggest an amendment to your test procedure.
Windows up > down as Baseline skue/ calibration run at the beginning of a test session to establish the current environmental conditions versus Baseline so that multiple iterations of a modification can be compared through time
But a fixed amount of fuel does not equal a fixed power! It closer approximates a fixed torque. But given the influence of that on the drag calculation (^2 rather than ^3), the basic approach should still be valid (on diesels anyway)
No.
Only for naturally aspirated diesel ( ancient dinosaurs not applicable to this discussion)
Diesel is a fixed amount of fuel not a fixed amount of power measured in Horsepower or Torque ,Diesel is a variable ratio engine. Therefore can make a variable amount of power on the same amount of fuel based on how hard the turbocharger is spooling changing the fuel ratio and power output.
With a fixed fuel rate if you increase the load on the engine it lights the turbo better resulting in a higher pressure ratio going into the intake leaning out the engine changing the power output continue loading the engine and continue building boost at the same fuel position. Observation of this fact, is the dividing line between Gas and Diesel Chassie Dyno operators; gas guys go to the floor and read the graph industry-standard that works, is accurate, and is backed up at the track. Diesel Dyno operator is going is going to throttle up to the window hit the brakes and throttle up to load the turbo once the turbo is loaded the brakes are released now you have a loaded dyno test for accuracy of your all out effort, that you can back up at the track. EG a diesel tuned on a chassis dyno using Gas techniques for 9.8sec in the 9.9 bracket class( bracket race speeds/times are dictated by safety equipment limitations) will brake out (produce more power than expected and exceed the safty limmits of of class required equipment, resulting in a banned from competition until New safety requirements of the next higher class are met ).
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
