Old 05-28-2020, 10:04 PM   #536 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
It felt like it wanted to wag the back of the car a little at 48mph when I got off the throttle.
I bet with some bricks in the car it would have handled better.
Sounds like the trailer is loaded wrong. Did you load the tongue at 10-15% of total? My Ranger is loaded worse and tows a 3000lb boat just fine weighing less than your Acura. I had a flat bottom that was loaded like 5% on the tongue and it trailered horrible, swapped to a bass boat triple the weight on the same Prius and it was loaded 12% on the nose and it was smooooooth.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following User Says Thank You to hayden55 For This Useful Post:
Ecky (05-28-2020)
