Old 09-21-2008, 10:16 PM   #82 (permalink)
stryker16
Mr. Taco - '01 Toyota Tacoma SR5 4x4
90 day: 16.18 mpg (US)
Originally Posted by tjts1 View Post
I still think you are better off just running a deep cycle battery charged at home every night and completely eliminate the alternator. 100 miles range is good enough for me 99% of the time.
Can anyone tell me if there is a difference between physically removing the alternator belt and just disconnecting the field windings. Obviously the latter has the advantage of being easier to turn on/off. I would think that it would still cause some parasitic drag on the engine though.
My intention is to make my truck run like tjts recommends, charging it each night. But I would rather not remove the belt as you never know when you will need the alternator to recharge the batts. Maybe the answer is as obvious as it seems I just wanted confirmation and couldn't find it.
