Old 05-29-2020, 11:36 PM   #3 (permalink)
EcoCivic
Originally Posted by California98Civic View Post
I like it. I did something similar with HVAC aluminium tape, foam, and leftover aluminium serving trays from an event. Helps. Needs some adjustment and repair now. Next time I have the bumper cover off....
Report back any improvement in cooling?
Subscribed.
Thanks. Honestly with my Mishimoto radiator my cooling system worked so darn well the way it was that I wouldn't see the improvement, even on a 100 degree day with the AC on the coolant temp sits right at the thermostat's temp of 182-186 degrees like it does in the winter. Without a thermostat, my cooling system would actually overcool the engine down to about 160 degrees even driving down the highway using the AC on a 100 degree day, which is darn good IMO.
I suppose once I finish my fan shroud, install ducting, and reinstall the bumper cover I will pull the thermostat out again and see if the cooling system could cool the engine even more after these mods, I think it will. Did you notice a cooling improvement when you did this?
