Old 05-31-2020, 09:37 PM   #6 (permalink)
EcoCivic
The only disadvantage to this mod that I can think of is that you may increase your intake air temp depending on how your air intake is set up and where it gets air from. I noticed no change in my IAT because my custom cold air intake draws air from behind the passengers side headlight and I made a heat shield to separate it from the rest of the engine compartment, but this is something to keep in mind if you are planning on doing something like this.
