Old 06-05-2020, 04:43 PM   #31 (permalink)
freebeard
Code:
The site I wanted to share is:
TechArt wind tunnel testing on pinterest. The smoke flow visualization clearly demonstrates that the air does not follow the 911's aft-body contour at all.
Looks like it's failing to paste. It should look like this before you click Submit:
Code:
The site I wanted to share is:[U*L="http://*URL*"]http://*URL*[/U*L]
Can you paste into the post directly? That will tell you if the paste is failing. Then click the link button and use 'x' for the url. Then replace the 'x' twice, once in the quotes and also between the brackets.
MY GTI wing is buried soooo deep. I might be able to get to it in a week.
