Thread: Prius 75-91mpg
Old 06-06-2020, 06:24 PM   #160 (permalink)
M_a_t_t
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Are you reinforcing a metal (steel?) skeleton for the reduced weight or just resin and carbon fibre?
I don't know the characteristics of carbon fibre, but I would atleast compare the compression and tensile strengths of the materials.
Theoretically you could reverse engineer the control arm to get the total resistance to deflect/bend in up/down and forward/back. The design of the control arm will reflect the characteristics of the material.
Then you could use the numbers for carbon fibre (and reduction % if you think safe to do so) to design the replacement.
The weight will depend on where the resin/fibre is. I don't think that a weight number is enough information to give any kind of reasonable answer. E.g. if you made a flat plate that weighed 50% the control arm it would probably snap. I doubt that a 1/4" carbon fibre plate will support the car. So redistributing the weight so that more of it is vertical will increase strength in the up/down direction
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
The Following 2 Users Say Thank You to M_a_t_t For This Useful Post:
bobo333 (07-09-2020), Nathan jones (06-07-2020)
