Old 06-06-2020, 07:39 PM   #43 (permalink)
JulianEdgar
Am I correct in thinking that the action is longitudinal rather than normal to the surface? Even though pressure diagrams use normals for magnitude the resultant is closer to toward the wake?
Of what, vortices? It doesn't matter what happens to them after the car - they can only act on the car through surface pressures. Therefore, measuring pressures at the centre of trailing vortices (not that I have done this specifically), and looking at the angle of the panel, will tell you the force direction.
But I might add that vortices is a very tricky area, one I couldn't get agreement on from my experts when I was writing the book. The disagreement was so strong that I did a panel on it (Page 19). I am at the moment in communication with a professional aerodynamicist about lift/downforce and vortices, and he is adding to my knowledge on this topic as we speak!
freebeard (06-06-2020)
