Old 06-07-2020, 10:55 PM   #16 (permalink)
JulianEdgar
So I think that using the pitot tube as a static reference is a much better approach than using the sealed vessel as the reference. Thanks again to cr45 for the excellent suggestion.
I have redone all of the Honda's measurements. Note that the basic pattern remains the same as with the previous measurements - for example, no negative measurements became positive or anything like that! However, I think with the pitot tube static reference, the absolute figures are much more accurate.
I also did an additional measurement in the middle of the roof because I suspected lots of lift might be being generated here because of the roof curvature (and I was right).
Test:
  • Pitot tube static reference located 2.2 metres above ground
  • Magnehelic 0-3 inch of water gauge
  • Custom measuring puck (easy to make yourself)
  • 11 degrees C, fine and clear
  • Light winds
  • 80 km/h test speed
  • Average of two measurements in different directions
  • Pascals rounded to 5
Note: the Insight runs full front and rear undertrays, with the rear undertray incorporating a 10 degree diffuser.
The Following 3 Users Say Thank You to JulianEdgar For This Useful Post:
COcyclist (10-22-2020), Daschicken (06-08-2020), MeteorGray (06-08-2020)
