Old 06-08-2020, 06:44 AM   #20 (permalink)
cr45
This looks very promising indeed and stagnation pressure is now where it would be expected to be.
I decided to have a look at the sensitivity of pressure to temperature change for a pressure box.
Using Gay-Lussac's law for a closed container then P2/T2 = P1/T1
Hence P2 = (T2/T1) * P1
Lets assume that the atmos pressure is 101325 Pa and the temperature is 10 C.
Also lets assume that the temperature of the air rises by 0.1 C by the time you take your aero measurements.
The new value for the pressure in the box will be
P2 = ((10.1 +273.15) / (10.0 + 273.15)) * 101325 = 101361
That is a difference in pressure of 36 Pa which is very significant considering the magnitude of the pressure differentials you are trying to measure.
The Following User Says Thank You to cr45 For This Useful Post:
JulianEdgar (06-08-2020)
