Old 06-08-2020, 07:14 PM   #12 (permalink)
j-c-c
Something not yet mentioned here, I believe there are some benefits to be gained from allowing/intending some (waste?)air flow also on the top side of a diffuser, especially if any DF is sought, effectively making it a turning vane with negative lift, if it has uniform cross sectional thickness, meaning, a sealed diffuser panel is not always 100% necessary or best.
The Following User Says Thank You to j-c-c For This Useful Post:
California98Civic (06-08-2020)
