Old 06-09-2020, 02:15 AM   #26 (permalink)
JulianEdgar
I tested a box cavity via pressure measurements in the wake.
Test:
  • Honda Insight
  • 14 degrees C
  • light, slightly variable winds
  • 80 km/h
  • two way average
  • 0-120 Pa Magnehelic
  • Pitot tube 2.2m above ground as static reference
  • Pressure sensor LHS, centre and RHS at bumper level
Without box cavity:
Centre: -18 Pa
LHS: -22 Pa
RHS: -20 Pa
Average: -20 Pa
With box cavity:
Centre: -16 Pa
LHS: -15 Pa
RHS: -18 pa
Average: -16 Pa
Now how significant is this? I am not sure. On the one hand you can say that the pressure was increased by 20 per cent - so that's excellent.
On the other hand, looking at the wake area (about 0.85 m^2), the actual force changes like this:
At 80 km/h, without box cavity, calculated wake drag = 1.7kg
At 80 km/h, with box cavity, calculated wake drag = 1.4kg
I doubt if a change of drag force of 300g at 80 km/h is significant - but perhaps it is?
But....
If the 20 per cent change also occurs on cars with big wakes, then it would become quite significant.
and...
This drag force will rise at the square of the speed, so at constant high speed, the drag force change (in absolute terms) of having the extensions will be much greater.
All very interesting.
(And yes, I am now much less skeptical of box cavities!)
The Following 2 Users Say Thank You to JulianEdgar For This Useful Post:
maczo (06-09-2020), niky (06-09-2020)
