Old 06-09-2020, 08:09 PM   #37 (permalink)
cr45
If you have a second pitot then you could test it in an alternative position but keep the present pitot at 2.2m and input the two static outputs to the one manometer - ideally your most sensitive one.
If the new position is accurate, the meter will give a zero pressure reading at a range of road speeds.
