Thread: Porsche Taycan
Old 06-10-2020, 07:31 PM   #3 (permalink)
JulianEdgar
* Two inches ( 50.8 mm ) would put it about right on 'template.' It's a heavy car. Nobody has complained about high speed stability.
I am sorry but this is becoming quite ridiculous.
Let's look at the actual facts.
1. As you'd expect from that high camber shape and attached flow, the Taycan has - even with the flat underfloor that would be offsetting a lot of it - front and rear lift. eg Clr = 0.16.
2. As you'd expect, that is an unacceptable amount of rear lift, so Porsche fit a rear deployable spoiler. That starts to rise from 90 km/h (56 mph). The spoiler position passes through three stages, and at its most deployed, drops CLr to 0.01 - ie basically no rear lift.
3. Nobody has complained about high-speed stability because the spoiler is deployed, massively reducing rear lift.
This idea that you keep pushing, that 'the template' will have low/no lift, is simply completely wrong. My on-road pressure measurements have shown your theory of how lift occurs on modern cars is wrong, and (what a surprise!) the Porsche Taycan shows that as well.
I don't care what you believe, but when you start leading others astray, that's not right.
The Following 2 Users Say Thank You to JulianEdgar For This Useful Post:
aerohead (06-12-2020), MeteorGray (06-11-2020)
