Originally Posted by Taylor95
I'm not sure right now if I could want to do that! My car has been in the shop for over 2 weeks now though so I just need to get it back. I suspect that i probably won't need to do that though. Do most diffusers just go to the rear bumper?
The issue is that (and I haven't looked under the Camry) the spare wheel well / trunk floor is usually the lowest part of the rear of the car - and it is usually fairly flat. Therefore, a panel that slopes upwards at the rear, and extends far enough forward*, is likely to be too low at its leading edge, reducing ground clearance.
* = maybe look at the video again? It's only 60 seconds long. Yes, diffusers go to the rear bumper but to work, they need to extend well forwards, and preferably join to a proper undertray.
I found with my Insight I had to work within quite narrow constraints in terms of diffuser length and angle (I didn't want to cut out the spare wheel well).
