Old 06-11-2020, 12:41 AM   #42 (permalink)
JulianEdgar
Originally Posted by JulianEdgar View Post
Yes it would - do you have a price?
I try to avoid using instruments that are too expensive for normal modifiers. The low cost digital manometer I have has a highest resolution of 0.1 inch of water - no good.
Edit - this looks good https://www.amazon.com.au/Perfect-Pr...22441494&psc=1
Second edit - just bought it.
The PerfectPrime AR1890 digital manometer has arrived. The instrument feels fairly cheap, doesn't come in any packaging and doesn't have an instruction manual (it is available here). But using the meter is self explanatory. It has a switchable backlight. Needs 9V battery (not supplied).
I compared its reading with a Magnehelic gauge - they match within about 10 per cent.
The meter needs to be switched to differential mode - its default is non-differential.
The meter also switches itself off after a while (25 min - but this can be disabled).
I have also now done multiple readings on the road. Set to inches of water, the display shows 0.00. The last decimal place is not really very usable because the on-road readings dance around a bit. So it might be showing 0.37, 0.45, 0.42, updating twice a second. So in order that you can select a mental average, you need to look at the meter longer than for a Magnehelic gauge (that shows a steadier reading). I suppose you could add some damping volumes to settle the digital manometer reading. You can select an averaging function but then you'd have to hold that speed for a reasonably long time (I am used to just getting to the speed and then noting the reading).
But the digital manometer is really cheap, can work over a wider range that a single Magnehelic gauge, and gather the data you want.
US$35 from Amazon for the meter and US$6 for the pitot tube static reference. Add a bit for some plastic hose and you're good to go.
Edit: I should add that the stagnation pressure on the Honda at 80 km/h was a measured 294Pa with the dig gauge.
Edit: I found the instruction book, that was included - along with a fitting and some short lengths of hose. (They were in the pouch the instrument can be stored in.)
