Old 06-13-2020, 12:08 AM   #18 (permalink)
EcoCivic
Originally Posted by California98Civic View Post
If you have pictures of your assembly and set up, they would be fun to see.
If you mean the setup of sealing the gaps, nothing has changed since the pics above with the exception of needing to put the sealing panels back since I needed to remove them to get the radiator out to install the fan shroud. Here's some pics of my newly built fan shroud though. Basically I made it out if 1 inch angle aluminium and a 1/16 inch sheet of aluminium. It isn't perfect, but it's quite functional and is therefore good enough for my purposes.
I have a question for you guys. I was very tired when I built the shroud and I forgot all about the flaps I said I was going to add to allow better airflow through the shroud while driving through the highway. The good news is the bumper cover is still off so it wouldn't be a big deal to remove the radiator to add flaps to the shroud if you guys think it would be a benefit?
ID:	28437   Click image for larger version
