Old 09-22-2008, 08:18 PM   #6 (permalink)
tasdrouille
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Originally Posted by Julian Edgar View Post
Vince, it is not for monitoring aftermarket sensors. It is for monitoring factory fitted sensors that already have their own control systems in place.
If you have a ScanGauge II with XGauge, which a lot of fuel economy minded folks have, and your car came with a factory wideband sensor, you can set up an XGauge to monitor the appropriate OBDII PID . It will give you the equivalence ratio, but you can display it as the AFR if you want. I've done it in my Elantra.
But if you don't have a SGII, that diy kit is the way to go.
www.HyperKilometreur.com - Quand chaque goutte compte...
