Old 06-24-2020, 01:03 PM   #39 (permalink)
aerohead
4-8 %
Originally Posted by gregersonke View Post
I don't see why it wouldn't work. Just adding two of them to my 2020 prius prime in the back on the black plasic piece behind the shark wing at an angle increased my fuel mileage about 4-8 percent in two different speed ranges 60-67 and 78+ but also drastically reduced my crosswind issues. Also I installed them with the high side of the vg facing forward to center of the car rather than backwards away from center.
Run the energy balance calculations on that data and compare to empirical data obtained in a laboratory, then see if you draw the same conclusions.
