Old 06-24-2020, 05:28 PM   #48 (permalink)
freebeard
Unfortunately I don't have anywhere near that much to make use of. So the solution needs to be relatively simple, and short or 'clipped'.
This is what I thought works before I started lurking on EcoModder. A chamfer, sort of a 'bullet-tail'.
https://ecomodder.com/forum/showthre...ail-33283.html
This is from Morelli. Instead of max camber at 30% of the length it has it at the rear putting the whole body in a favorable pressure gradient. Pending aerohead's agreement.
aerohead (06-26-2020), Engeu1 (06-24-2020)
