Old 06-25-2020, 03:09 AM   #32 (permalink)
M_a_t_t
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Rebuilt a wheel cylinder. It came apart fairly easily. I forgot to grab a before picture, but you can probably imagine what it looked like.
The center cap I powder coated is fighting to keep the red on the cap. I had to turn the psi up all the way to get it to start budging. It's slowly coming off. The chrome came off pretty quickly. I'd assume it has to do with the thickness though. I also lost the center cap in the bottom of the blast cabinet. When something is taking forever to clean off I like to break it up and do something smaller for a little bit. Well I was cleaning up the wheel cylinder and parts and when I went to start on the center cap again it was missing. I had to open the trapdoor and start draining the media out to find it.
I started removing the front brake parts. At first I couldn't figure out how to remove the wheel bearing. Then I remembered to check the chilton and not just the assembly diagrams on CMSNL.com. The chilton says to remove the caliper. Then undo the ball joint, tie rod, and strut and remove the knuckle. Then I can start dis assembly to change the rotor and wheel bearings.
Getting the axle out was actually very easy though. Used an impact on the axle nut and a single hit with a hammer and it popped out of the knuckle.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
