Old 06-26-2020, 01:14 PM   #319 (permalink)
mpg_numbers_guy
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
Did the price change on that? I'm seeing $200 when I thought the pre-built ones used to be $280, hence why that 2nd option I was considering was building it myself using those cells. $200 isn't bad if it includes a case and some basic balancing boards. -4*F minimum charging temperature is tempting too compared to the typical 32*F threshold. 40A max continuous discharge shouldn't be an issue since the meanwell doesn't charge much higher than that and has had no issues so staying below 40A shouldn't be a problem at all.
Did you replace the connectors on that battery? They look pretty flimsy.
EDIT: Ah, I see now that the tabs can be removed.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
