Old 06-27-2020, 12:33 AM   #50 (permalink)
Xist
Cadet's Log: Supplemental
The bad heater cores are distracting me from smaller problems. Harbor Freight closed before I got there on Wednesday. I returned on Thursday and they had every pump but the one that I wanted to flush my system, so I ordered it, but the radiator fluid ran clear after one bottle of Dollar Tree CLR and two liters of water, although I am going to flush out the CLR.
I am supposed to reverse the hoses and backflush, right? Hopefully the other hose is long enough. I chose this setup to ensure that the funnel was higher than the fender, but I should have run the tubing over the front of the car anyway.
Is it too late to cancel the pump?
I e-mailed the eBay store every day this week and never heard back. I cannot even leave negative feedback. I just ordered the same part from AutoZone for a couple of times as much (with discount!), but it will not be here for a week and a half.
I guess that I will remove the dash tomorrow and then try to clean the carpet.
