Going from your ignition switch to the fuse block.....There should be a RED wire with a YELLOW tracer. That should be your 12volt wire that applies voltage to the starter to pull the solenoid in, So that it cranks. That RED/YELLOW wire.. I think plugs into the face of the fuse block and is close to the size of a 10/12ga wire. I myself thru a relay in, in my '95 ....to take the load off of the switch. Good luck
How about a 1 Litre Street rod?
