Old 07-03-2020, 03:33 PM   #3 (permalink)
serialk11r
A thought I had was instead of using fasteners (place where water can leak in), over parts of the body that don't need to be serviced (e.g. most of the floorpan aside from the center tunnel), you can attach a foam backed fiberglass panel with adhesives to the floor directly to basically make a smooth extension towards the ground.
The stuff they use to attach the hood support frames would probably work?
