Originally Posted by SkauneJohan
Yeah i know, methanol is the preferred alcohol, it even adds some energy (power) problem here is it is very very expensive, only cheapish alcohol is E85 and then you gotta remove the gasoline after blending it with water.... only other solution is washer fluid wich also is ethanol here and quite expensive
Is homebrewing vodka totally out of question?
My though was that they maybe also used the vacuum for the automatic gearbox but they did not, it seems to be only EGR wich is nice
So, does its torque converter not feature a lock?
