Old 07-07-2020, 02:03 AM   #72 (permalink)
freebeard
The 1302 had two years of production, hence Galane's question. It's the same as the Standard from the A-pillar back, but the frame head, suspension, hood and fenders are different. 1973 and later is the 1303. 1975 had rack and pinion steering and revised Macpherson struts. That's the front suspension I want to use on my 1958 Baja, on an eight inch frame extension to make it a rat rod.
The sway bar that locates the lower end of the struts would be reversed.
I've got an aftermarket stress bar on the struts. PNW lighting again.
OP — Sorry for the threadjack.
bobo333 (07-09-2020)
