Old 07-08-2020, 11:38 PM   #12 (permalink)
cRiPpLe_rOoStEr
Originally Posted by serialk11r View Post
If that were true, then electronic wastegates wouldn't be useful.
But they don't decouple anything. Their purpose is to better direct the exhaust flow and to provide some eventual restriction as some sort of exhaust-brake.
Spinning the compressor at part throttle is wasted energy because the precise opposite of what you need is more airflow and more pressure.
It used to be more critical for older vehicles with either a carburettor or port-injection than with the newer direct-injection gassers, not to mention the downsizing trend.
Converting that turbine shaft power to electricity is harvesting wasted energy.
Just like some engines have an intercooler bypass for cold start maybe a compressor bypass could be tried, as long as some coupling from the center shaft of the turbo to a motor-generator is provided.
