Originally Posted by cRiPpLe_rOoStEr
Makes me wonder if it would actually improve access to the drawer if you got rid of the armrests on the rear door trims.
The maximum door opening angle is the limiting factor, not the shape of the arm rest. I could make the drawer 3-4" longer (wider when facing the front of the car) with no arm rests, but its already over 4ft long so i havnt justified the effort of custom door trims yet.
Originally Posted by California98Civic
Nice work! Put some partitions in that drawer to keep stuff from moving around and mixing up and making noise and maybe getting damaged?
I will probably end up with a few partitions once ive lived with it a while and decided what goes where.
What you need to go in top of all that is a self inflating sleeping pad. They have inner structure and open cell foam.
I currently use a basic 4" foam mattress but its not the most comfortable after a few days of squishing it down, eventually il probably upgrade to a nice memory foam one cut to fit the space with a soft topper, it doesnt really need to fold up as small or be as light as the expensive self inflating ones.
