Old 07-11-2020, 09:58 AM   #89 (permalink)
ACEL
Ecomodder
AcuraMatata - '99 Acura EL Base
90 day: 36.82 mpg (US)
Le Vehicle - '12 Dodge Gran Caravan SE
90 day: 24.27 mpg (US)
Wheel covers heresy or just appropriate to this car?
Science is ever evolving. Until there is new knowledge, basic tenet holds and sometimes the knew knowledge seems like "heresy". In the past "general universal explanations" were developed and as long as no new facts and data became available, the "general universal explanation" figured as "the law". Today, science recognize that there are both the "general universal explanation" and many "particular solutions" applying to specific situations or devices. General universal solution" is often expressed in general terms and simple equation. The "truth" applying to one specific situation is much more detailed and vary somewhat from the "law". As an engineering professor said in my first year in university, "physics is an exact science as it describes a situation in general terms and then searches for the particular applications; engineering is the inexact science of applying the laws of physics to real applications; engineering solutions may be as far as 100 % from the truth but are narrowing the range around the exact solution through the years. e.g. see the heavy piston engines of the beginning of the 20th century (connecting rods especially) producing little power because of so much inertia compared to the actual piston engines.
So, the fine solution for some car is not necessarily the appropriate solution for my car. It saddens me for I have to search and experiment to confirm the solution that works for the situation at hand. This is also science.
Before to fabricate and install the "definitive" wheel covers on my 1999 Acura EL, two mock-up were tested. First was an open perimeter wheel cover. Second was an almost full wheel cover with the wheel center open (pics). Tape mock-up was installed on all four wheels to get aerodynamics information.
The goals are :
1. Find the most appropriate wheel cover for this 1999 Acura EL car in terms of actual fuel economy and aerodynamics behavior.
2. Determine which wheel cover will allow brakes heat to escape.
3. Aesthetic constraint: the final wheel covers have to look good on the car and not disfigure the good looking wheels (wifey requirement)
To measure the parameters to satisfy goal 1, Torque Pro App was used to log : throttle opening (%), acceleration (x), mileage instant, RPM, Speed GPS. The data series were logged every half second.
To satisfy goal 2, simple observation and "touch feeling" were used
Goal 3 is satisfied when "wifey" says it looks good. She did. See pics.
Testing of the mock-ups were conducted "back-to-back" on the same morning and road segment. The previous day, on the same road and similar conditions a series of runs without any cover were done in order to obtain a baseline data for comparison.
The metrics for comparison were the top speed achieved at a constant throttle opening according to the "throttle stop" method proposed by Julian Edgar on Youtube. The instant mileage averages over the few seconds that the speed remained constant at the said throttle opening were also compared.
Tests were conducted in the following order:
0. Baseline test, no covers (32 Celsius)
1. Open perimeter mock-up (17 to 20 Celsius)
2. No perimeter mock-up (17 to 20 Celsius)
3. Final wheel cover installed
Results and observations:
1. Open perimeter mock-up : allowed a top speed increase of 1 to 3 % over the base line even though the air temperature was lower by more than 10 degrees Celsius.
Revised data and results on July 12: Top speed increase 7 % at 111-112 Km/h (60 mph); no significative difference over baseline result in top speed at 122-124 Km/h (76 mph) - Fuel consumption decreased 4 % at 111-112 Km/h and 3 % at 122-124 Km/h (20% throttle opening) .
2. No perimeter mock-up : REVISED DATA : ALLOWED THE SAME TOP SPEED INCREASE OF 7 % at the same speed of 111 Km/h but a top speed decrease of 2 % for the same throttle opening of 20 % (119-121 Km/h)). (Previously reported:"did not allow an increase in top speed as the open perimeter did. On the contrary, it decreased the top speed obtained by the open perimeter mock-up by at least 13 %"). REVISED DATA Allowed a fuel consumption decrease of less than 1 % at 111 Km/h but of 9 % at 122-124 Km/h.
Also, the tape on the wheel perimeter felt hot to the touch on one front (disc) and one rear (drum) wheels. For mileage, the open perimeter mock-up used at least 7 % less fuel than the full perimeter blocked wheels. The final wheel covers will be with an open perimeter like the Tesla "aero" wheel covers and the design will have to match the underlying wheel.
3. Final wheel covers (17 Celsius : same road): Projected wheel covers fabricated with aluminum pizza pans and decorated with back sticking lettering vinyl was okay’ed for aesthetic.
These final wheel covers did not allow for a significative increase in top speed for a given throttle opening over the mock-up open perimeter wheel covers (increase of 1 - 3 Km/h in 120 - 125 Km/h range and 20 % throttle opening). On the other hand, fuel economy was improved by 2 to 5 % in the same speed range over the said mock-up. No particular heat accumulation was felt on the perimeter of the aluminum pizza pans.
Conclusions
Cheap modification mock-up is a good way to test various alternatives to orient the search for the appropriate modification.
Definitive wheel covers design retained are appropriate to the 1999 Acura EL and are proved to be a worthy modification that saves fuel.
ID:	28697   Click image for larger version
ID:	28698   Click image for larger version
ID:	28699   Click image for larger version
ID:	28700   Click image for larger version
Acel
See many mods in detail with results on my modification thread for my 1999 Acura EL, similar to US Civic EX
Facts, please, give me the facts! Theoretical knowledge is verified by empirical knowledge! Check Einstein's General Relativity Theory E=MC^2! Every few years some new astrophysics observation and data prove some of Einstein's theory predictions more than a century old.
The Following 4 Users Say Thank You to ACEL For This Useful Post:
California98Civic (07-11-2020), COcyclist (07-12-2020), freebeard (07-11-2020), Joggernot (07-13-2020)
